planning for installation.
6 minutes ago, pinball001 said:But do I need to prepare the drive in some way, like removing the bit of plastic with the branding?
Nope, that sticker is conductive, it would actually hurt to remove it.
6 minutes ago, pinball001 said:Lastly, does it matter how closeness to the cpu affect performance?
The specific slot matters, yes, but not really because of the distance between it and the CPU. Different slots get different PCIe lanes allocated to it, some come directly from the CPU, some come from the chipset, and some take GPU lanes. Slot 1 is directly from the CPU using the lanes dedicated for it, so that's probably the best slot for it, though slots 3 through 5 will likely be unnoticeably different. Slot 2 steals 8 lanes from the GPU though, so I would avoid using it unless necessary.
