Can anyone help!
Go to solution Solved by Volbet,
The PC can run in safe mode but haven't tried reinstalling windows!
If it can run in safe mode, it would seem like it's a software issue. Either try reinstalling some of the drivers, like the graphics card driver and the chipset driver.
If that doesn't help, I would suggest reinstalling Windows.
Edit: You can also check if Windows is broken. Run the CMD as administrator and write ´SFC /Scannow´ into it. This will scan Windows for any missing files,
My dad's computer is having a few problems lately it keeps freezing and crashing, BSOD and No signal input and weird lines!
The specs are:
AMD phenom 955pe
Asrock 880GMH/USB3
The ram is this :http://www.novatech.co.uk/products/components/memory-pc/ddr3pc3-106001333mhz/ram-13334.html
Ati HD5450 (using vga)
320gb samsung hdd
i have ran memtest no memory errors, ccleaner and updated all drivers but this is what happens all the time:
post-22369-0-49851400-1399659203_thumb.j
post-22369-0-88246600-1399659214_thumb.j
Thanks for any help to fix this!
| Ryzen 7 3700x | 16GB Vengance @ 3200 | MSI GTX 1070Ti Gaming |
| ADATA XPG SX8000NP 256GB Nvme SSD + WD Blue 500GB SSD | 4TB WD Blue |
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/
Can you upload the dum file (located in C:/Windows/minidump)? This will give us the BSoD error message, making it a bit easier to troubleshoot.
Does the PC boot into safe mode OK?
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004260
It boots fine in any mode! and i will upload the dum file ;)
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004265
There are no files in the Minidump folder at all
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004280
You might have to set it to make a dumpfile (I thought that was on as default)
Search for ´sysdm.cpl´ → Click the ´Advanced´ tab → Click ´Setting´ in the ´Startup and recovery´ setting → Check ´Write an event to system log´
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004302
Ok ill try that!
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004304
It was already checked!
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004326
I'm becomming more and more convinced that Microsoft hates me.
What temperature is the CPU running at? It might be a overheating problem.
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004342
At idle 34 Degrees C with AMD stock cooler.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004359
i'd say ur gpu fried it self or somthing. try a different gpu
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004395
What about the stress temperature?
Tress temps are 66 Degrees C!
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004396
This happened on motherboard built in gpu that's why we put a HD 5450 from my system to his and it worked fine for 8 months in my system!
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004401
So the CPU temperature isn't the problem.
I would agree that it then seem like a problem with the graphics card. Try the card in a different system or try a different card in your dad's system.
Edit: Didn't see you post. Can the PC run in safe mode? Have you tried reinstalling Windows?
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004404
This happened on on-board gpu on motherboard that's why i switched it to my older but fully working HD5450
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004407
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004452
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004457
Ok thanks for your time and help! :)
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/149947-can-anyone-help/#findComment-2004463
