HP-14cm0095au, confusing DC and Battery issue
Check the DC power jack: Inspect the DC power jack on your laptop for any signs of damage or looseness. If you notice any issue, it might need to be repaired or replaced.
Check the AC adapter: Use a multimeter to test the voltage output of your AC adapter to ensure it's providing the correct voltage for your laptop. If the voltage is not within the acceptable range, you may need to replace the adapter.
Check the new battery: Although the battery is new, it's possible that it could be faulty. If you have access to another compatible battery, try using it with your laptop to see if the problem persists. If not, you might need to replace the new battery.
Update BIOS: Some laptops may require a BIOS update to properly recognize and charge new batteries. Check your laptop manufacturer's website for any BIOS updates specific to your model.
Perform a hardware reset: Unplug the AC adapter and remove the battery. Press and hold the power button for about 30 seconds to drain any residual power. Reconnect the AC adapter and battery, and try powering on the laptop.
