having problems with usb-c on motherboard not being in device manager. please any advice
so i recently bought quest 2 (but this problem isnt about quest 2), plugged it into pc with usbc to usbc cable and it says its usb 2. then I checked device manager and theres only 7 ports when theres 8 in reality and theres simply isnt this usb c port.
then trying to investigate this issue i downloaded usbtree and saw that its port 4 but it says  PortConnectorIsTypeC : no and thats its not usb 3 when im 100% it does.
every other port works fine its just that this particular port which is usb c just works like usb 2 and i cant even manage it in device manager. i could use use usb a with quest 2 but usb 2 has no power to charge headset but usb c has more then plenty power for quest.
updated chipset drivers , reinstalled gpu drivers, installed windows update, updated bios to newest version, tried installing new usb drivers but theres new one, and stuff that i cant remember anymore
so please if anyone knows what could be cause for this weird behavior usb c port on motherboard
motherboard : asus rog b450 gaming 2
cable : kuject usb c to usb c usb 3 cable
thank you and please any ideas are welcome
5 minutes ago, plsguyshelp said:
anyone please?
Show the screenshot from USBTreeView
Main System (Byarlant): Ryzen 7 3800XT | Asus B350-F Strix | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 960 PRO 512GB / Samsung 970 EVO 500GB / Crucial MX500 2TB / Crucial MX500 500GB / WD White 7200RPM 8TB | Corsair RM750X | Intel X540-T2 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
TrueNAS Server (Veda): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2x 1TB HGST 2.5" / 2x Samsung PM963a 960GB SSD / 1x Kingston 16GB SSD | Seasonic Prime Fanless 500W | Mellanox ConnectX-3 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Hauppauge ImpactVCB-PCIe | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
(500Mbps↑/500Mbps↓)        ┌─────────────── Office/Rack ──────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch Flex XG ═╦╤╦═ Veda (general traffic)
╔════════════════════════════════════════════════════════════════════════════╝│╚═ Narrative (Asus 2.5G USB NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ─────────────────┐        └── UniFi Switch 8-60W ─┬─ Veda (management)
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═══╦═ Byarlant                                       └─ UniFi CloudKey Gen2 (PoE)
   (PoE)                 │                          ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Narrative** (Belkin USB-PD Ethernet Dongle)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Kingston 120GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M (?) | HooToo USB 3.0 PCIe Card | NZXT H230 Case (mostly intact, but some parts have been scavenged)
Parts: PNY RTX 3060 Ti XLR8 Gaming Revel Epic-X | Mellanox ConnectX-3 10G NIC
here connected to usb c, saying its not usb c and its usb 2.1
any ideas?
any ideas?
Flip the cable 180°? It's showing as connected to the USB 2.0 portion of port 1-8, but it's not negotiating USB 3.x speeds, which could be any number of issues from bad cables to bad connectors to bad luck.
Network:
Retired/Other:
well flipping didnt help, tried another cable with another device and it says usb2.0. can it really be connector, motherboard is like brand new opened 1 month ago, some other people reported similar problem with b450 chipset. so no solution im stuck with usb-a?
I had something similar happen to my Zenbook, tried reinstalls, bios updates, the works, ended up finding an old thread on reddit about someone with a HP laptop who found a fix somewhere else: holding down the power button for about 50 seconds, it worked for them and it worked for me. Sounds stupid I know, but worst case scenario, it cost you 50 seconds
