howdy all, im looking to get some help with an over clock on my system specs below. i know there's probably a billon guides and ways to learn but i know what im good at it and tbh scared to dive in to it and mess something up. ive built a car from the frame up but the numbers and ocs xmp jarggles my brain im more then willing to buy someone a coffee (or tea whatever the pref) for the help
add my discord if youre willing to help a fellow techy out 🙂 Ȓed#6101
https://linustechtips.com/topic/1497967-help-with-overclocking/
Overclocking a 9900K is not really all that difficult, there are just two things that matter: voltage and clock speed. Your goal is to find the balance between clock speed, voltage, and temps to get the best performance. This is the method I'd go for personally:
  1. Configure a half decent LLC setting. IIRC you find this in Tweakers Paradise, but set the LLC mode to something like level 2 or 3.
  2. Set some initial values. These will be wrong, but they're just to get you started. Set VCore to 1.3V, the core ratio to 45, and the uncore/cache/ring to 40 (all of those refer to the same thing, I just forget what ASUS calls it).
  3. Go into Windows and run a stress test for a few minutes.
    1. If it's stable and temps are OK, increase the core ratio in the BIOS.
    2. If it's not stable and temps are OK, increase the voltage by 0.025V.
    3. If temps are not OK, decrease voltage by 0.025V.
    4. If it's not stable and temps are not OK, decrease core ratio multiplier and retune the voltage.
  4. Repeat step 3 until you find the balance between core clock and voltage. Run the stress test for 30 minutes to make sure it's initially stable.
  5. Increase the ring ratio until it's unstable.
  6. Run a stress test for 2 hours to make sure it's fully stable, repeating step 3 if it's unstable.
There is debate for what stress tests are the best for this. Linpack Xtreme is a big one, Prime95 Small FFTs is another one, OCCT is also a thing.
https://linustechtips.com/topic/1497967-help-with-overclocking/#findComment-15872357
On dime boards, the bios has an auto overclock menu.  You can select 9900k 5.0ghz for example.
May be a way to start slow and see what performance you can get.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1497967-help-with-overclocking/#findComment-15872493
tldr: this is why i dont overclock 🙃
i prefer undervolting honestly anyway (except that doesn't seem to work on intel either,  so only amd for me i guess)
-Scott Manley, 2021
https://linustechtips.com/topic/1497967-help-with-overclocking/#findComment-15872764
I've had more issues undervolting on AMD than I have on Intel though. Undervolting on AMD causes either massive clock stretching (AKA clock speeds are high but performance is terrible) or if you use the curve optimizer crashes at idle that are next to impossible to diagnose. On Intel you just adjust one dial assuming you have a Z- series board and you're done (it is kinda broken on B- series boards though).
Besides, it's not like it's that different to overclock than it is to undervolt. Only difference is you're trying to increase the multiplier at the same time.
https://linustechtips.com/topic/1497967-help-with-overclocking/#findComment-15872772
its what you're targeting too though,  to me its always temps and for example my 3600* at -200 voltage offset didn't have "clock stretching" it just boosted the same but longer so performance went up (since temps where lower) same for my 5800x3D,  gtx 1060, gtx 1070 and rtx 3070 (my intel i5U just crashes whatever offset i set though...)
*interesting: at stock it would use 65w just like advertised, with -200 voltage/+200 frequency offset it was off the rails at ~110w  😮
-Scott Manley, 2021
https://linustechtips.com/topic/1497967-help-with-overclocking/#findComment-15872796
39 minutes ago, Mark Kaine said:
its what you're targeting too though,  to me its always temps and for example my 3600 at -200 voltage offset didn't have "clock stretching" it just boosted the same but longer so performance went up (since temps where lower) same for my 5800x3D,  gtx 1060, gtx 1070 and rtx 3070 (my intel i5U just crashes whatever offset i set though...)
Where as this is what happens if I try to undervolt using offsets.
No offset:
-200mV offset:
-300mV offset:
The core clocks keep going up, but the overall score goes down. I've seen it be a lot more extreme that this, maybe because the AGESA version I'm using isn't as bad for this or because I'm doing it in the OS with Gigabyte EasyTune (I'm lazy and this is my daily system after all), but the behavior is still there and noticeable. Heck, on one AGESA version I used the score would actually go up if I used a positive voltage offset. All the Intel chips I've used have kept their performance the same when doing this, and their stability is actually consistent unlike this 5900X where if I touch the curve optimizer I get random blue screens when watching YouTube even though it passes any stress test and game I throw at it. The Intel chips either work or they don't, not somewhat working or reducing performance if you don't have the voltages dialed in just right.
https://linustechtips.com/topic/1497967-help-with-overclocking/#findComment-15872828
but thats what i said does not happen... it didn't go up, always 4.1/4.2, the difference is it boosted longer which you can only see due to benchmarks going up, cb23 like 500 points for example,  personally i find that laughably low, but its a difference others seem to be happy about  - i really only care about lower temps (overall)
also, im sorry, just from voltage offset the clocks shouldn't go up cause its locked by multiplier,  42x (?) ... so there must be something else going on there
-Scott Manley, 2021
https://linustechtips.com/topic/1497967-help-with-overclocking/#findComment-15872848
