I like the Fractal Design Define R4. In my case (pun intended), I would go with windowed. The NZXT 410 looks too plain, and I don't like the Corsair Carbide series.
I don't see how any of NZXT's Phantom line would be seen as too plain compared to boxes like the R4 and 400r. Nothing against Fractal and Corsair, they make great cases, it's just that some people don't like their cases all square like.
https://linustechtips.com/topic/149729-case-help/#findComment-2001073
If you like the phantom 410. Get the phantom 410. Although i would suggest moving up to the 530 if your budget allows. It has some significant improvements over the 410 while still maintaining the same style.
Also known to his peers as Lord Scrubby McScrubington
https://linustechtips.com/topic/149729-case-help/#findComment-2001092
Oh I mistakened it for the H440. The Phantom would be fine if you like it, in my case though (pun intended), my OCD hates the Phantom's non-symmetrical design.
https://linustechtips.com/topic/149729-case-help/#findComment-2001096
Which case has the better airflow?
The Phantom 410 has better airflow.
https://linustechtips.com/topic/149729-case-help/#findComment-2001585
