at the end of the day im not to worried i want to see if i cant fix the picture tube tvs are a pain they are heavy as F, anyways just turned it one and the color is all out of wack i took off the back being careful not to electrocute myself with the cathode tube, but the dials on the PCB is the color fixable from a drop or do i need to store this in the attic for the next tenants for find
https://linustechtips.com/topic/1495215-1994-tv-help/
8 hours ago, mariushm said:
Looks like the tube is magnetized, the monitor should DEGAUSS itself with repeated on/off cycles
Move away speakers or anything with magnets from it.... not much you could do.
sounds fixable not going to go all out to fix an old tube tv for console gaming and retro pc im no "8BitGuy"
https://linustechtips.com/topic/1495215-1994-tv-help/#findComment-15851008
