Video and Audio stuttering with RX7900 XT
Solved by Kurz-Weber,
Oooooooooooooooooooohkaaay... I think, I could solve it!
I've searched through nearly all AMD Community posts, which could be related to my hardware setup, and found some posts.
So, apparently the combination of having a CPU with integrated graphics (looking at you AMD Ryzen 5 5600G) and the BIOS PCIe Gen + lane configuration, is error-prone.
My setup was:
- RX7900XT graphics card in PICE1-Slot
BIOS PCIe Options:
- Lanes x16
- PCIE x16 Bus Interface: Auto
I changed the BIOS config to:
- Lanes: x8x8
- PCIE x16 Bus Interface: Gen4 / Auto (both works)
And guess what: Problems are gone! It seems like, that Ryzen 5 5600G can't handle Gen4 x16?.. ...
- https://community.amd.com/t5/drivers-software/audio-clicks-pops-since-installing-rx6750xt/m-p/591454#M171137
- https://community.amd.com/t5/drivers-software/audio-makes-cracking-and-popping-noises-after-gpu-install-rx/m-p/590850/highlight/true#M170983
- https://www.reddit.com/r/Amd/comments/11no3nd/a_detailed_summary_of_the_crackling_problem/
So, do you think, it's okay, or should I get another CPU? Any recommendations?
