Budget (including currency): 1000-1100 euro
Country: germany
Games, programs or workloads that it will be used for: content creation, comp gaming
i configured two pc builds but i dont know which one is better. so i would like to have your suggestions and tips
(i plan to put 3070 or 3080 in the pc, but its not in the budget here)
https://de.pcpartpicker.com/user/Golden77/saved/#view=wry4gs
https://de.pcpartpicker.com/user/Golden77/saved/#view=HmTJwP
https://linustechtips.com/topic/1495142-suggestions-for-my-build/
39 minutes ago, Hendrik__ said:
streaming and editing
then go for an nvidia gpu
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
OP already says that they are going to add a 3070 or 3080.
PC1 is already very good but that H510 is a deadweight. I highly recommend you to swap to the similarly formed Fractal Design Pop Air which has better opened front panel and better integrated fans than that of H510, which would also omit the need for a fan pack. From there you should get yourself a 2TB nvme SSD because 1TB is not a lot to go off of nowadays.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Total: £1040.95
