3 minutes ago, tommoose13 said:
Does anyone know if there's a 3d print file somewhere of a bracket to surface-mount a typical atx power button?  Or if something like this already exists for purchase?  Horrible paint mock-up included below!
one of the funniest ones i found
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
7 minutes ago, RONOTHAN## said:
Things like this exist that should do what you want it to.
Thanks for the reply! Unfortunately, this won't do what I want it to do. I'm working on converting an old Coca-Cola fridge into a PC case and want to utilize one of the dispenser buttons as the power button, and the tiny button fits just perfectly, with room for either a glue puddle or small bracket to mount it in place. I'm hoping to avoid hot-glue to keep space available for RGB strips in close proximity.
What you could do is salvage the button that was already in there and just redo the wires to the PC ATX wires that you would need. It's really not that difficult to wire up, all you'd need is a donor set of front panel headers.
I'm just confused by this one image.thumb.png.b9720ce2c07e2791c7dc90a5b3c7f312.png
Total: £1040.95
Why not just use the dispenser button?
Cut the wires and connect them to onr that fit the board all you need is a short time completed circuit to trigger a boot
That's a great idea!  Unfortunately, there is no electrical button to salvage; the original setup had 6 push-buttons on the front that pushed a plastic mechanical button that dropped drinks down.  All that's left is the push-buttons in the door front, and I need to get a switch behind one of them.
Pictures below of what I'm working with.  Red door closes onto thin white piece beside it with small holes where drink dispensers used to be.  Push posts embedded would push the small switch if mounted in one of those holes perfectly.
Got it, that makes sense. Right about now is when I wish Radio Shack was still a thing, odds are you could just head in there and find the exact switch that you needed as well as some sort of mounting bracket in there as well.
What are the dimensions of those holes? Finding one of the screw on momentary switches is still likely going to be the easiest idea, both in terms of ease of installation and actually being able to find them, and while yes, you'd have to super glue a peg in there to get it to work with the stock Coke buttons, it still should be OK.
If only RadioShack were an option!  The holes are 7mm in diameter.  I am really hoping to find something similar in size to the switch I originally pictured, idea being to make it invisible from the window beside if possible.
https://www.amazon.com/Solder-Free-Momentary-Normally-Terminals-Included/dp/B07DD245FV
These might just do the trick. They need to be screwed in place, but odds are with something like that you wouldn't be able to see them anyway.
Genius!  I happen to have one of these laying around and it test-fits the hole perfectly.  Only one problem, the door closes flat against the thin panel, so the switch needs to be flush with the hole...  😕
Well, @mononymous you may be right.  Took me a couple hours to figure out how to use it since I have zero CAD experience, but I downloaded fusion360 and discovered my local library provides 3d printing services. Made flush mount v1 (pictured below) and will follow up in this thread with how the print goes once I pick it up from them.  Once I have a model that works I'll attach it here in case others want to use it!
Got calipers same day as the print arrived, I was off by 1mm on the spacing.  Sandpaper fixed mine, but I updated the CAD file to fit correctly, and extended the bridge piece to the one side, since only one side needs the indent for the wires.  Attached STL and F3D files in case anyone wants to use or edit this design!
ATX Power Button Flush Mount v3.stl ATX Power Button Flush Mount v3.f3d
Post the files on printables, thangs etc. Welcome to the world of prototyping with 3d printers.
AMD Ryzen 5 3600 | AsRock B450M-Pro4 | Zotac GTX 3070 Ti
Shure SRH840A | Sennheiser Momentum 2 AEBT | LG C9 55"
