First PC build- Will it all fit together?
Budget (including currency): 2500
Country:  USA
https://pcpartpicker.com/list/PQxNtn
**CPU** | [Intel Core i9-13900K 3 GHz 24-Core Processor](https://pcpartpicker.com/product/DhVmP6/intel-core-i9-13900k-3-ghz-24-core-processor-bx8071513900k) | $569.99 @ Amazon
**CPU Cooler** | [Cooler Master MASTERLIQUID ML240L RGB V2 65.59 CFM Liquid CPU Cooler](https://pcpartpicker.com/product/fLFKHx/cooler-master-masterliquid-ml240l-rgb-v2-6559-cfm-liquid-cpu-cooler-mlw-d24m-a18pc-r2) | $89.99 @ B&H
**Motherboard** | [MSI PRO Z790-A WIFI ATX LGA1700 Motherboard](https://pcpartpicker.com/product/8m6p99/msi-pro-z790-a-wifi-atx-lga1700-motherboard-pro-z790-a-wifi) | $259.99 @ Amazon
**Memory** | [G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory](https://pcpartpicker.com/product/mhJgXL/gskill-trident-z5-rgb-32-gb-2-x-16-gb-ddr5-6000-cl36-memory-f5-6000j3636f16gx2-tz5rk) | $139.99 @ Newegg
**Storage** | [Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive](https://pcpartpicker.com/product/Zxw7YJ/samsung-970-evo-plus-1-tb-m2-2280-nvme-solid-state-drive-mz-v7s1t0bam) | $69.98 @ Amazon
**Video Card** | [MSI VENTUS 3X OC GeForce RTX 4070 Ti 12 GB Video Card](https://pcpartpicker.com/product/QX92FT/msi-ventus-3x-oc-geforce-rtx-4070-ti-12-gb-video-card-rtx-4070-ti-ventus-3x-12g-oc) | $839.99 @ B&H
**Case** | [HYTE Y40 ATX Mid Tower Case](https://pcpartpicker.com/product/2djBD3/hyte-y40-atx-mid-tower-case-cs-hyte-y40-b) | $149.99 @ Amazon
**Power Supply** | [Corsair HX1000i (2022) 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply](https://pcpartpicker.com/product/XBVmP6/corsair-hx1000i-2022-1000-w-80-platinum-certified-fully-modular-atx-power-supply-cp-9020214-na) | $259.99 @ Best Buy
**Sound Card** | [Asus Xonar SE 24-bit 192 kHz Sound Card](https://pcpartpicker.com/product/HDHRsY/asus-xonar-se-24-bit-192-khz-sound-card-xonar-se) | $39.99 @ Amazon
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$2419.90**
This is going to be my first ever PC build and I'm just wondering if all of this will fit in the case and work together. Also any other suggestions on the water cooling or will this one I picked work out well? Also I just picked a random cheap sound card, do I need one at all?
Open to any changes you think will be better but the i9 and 4070 I cant change.
Is there any reason why? What are your uses?  You will definitely need a better cooler for a 13900k though
I have someone who is giving me those two parts so I'd like to work around them
Country:  USA
You'd be better with an i7, costs less and less power consumption, with an i9 you need a beefier 360 cooler imo
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 / RTX3080 Gigabyte EAGLE GPU/ Phanteks P600S case / Customized Watercooling Eisbaer 280mm + Eiswolf2 360mm + VPP755 pump  and 150mm reservoir0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
21 minutes ago, tOASTY11211 said:
would this be a better cooler?
A 360mm aio is probably what id be looking for in terms of cooling a 13900k. Only slight problem is the hyte y40 only supports up to a 280mm aio. You'd have to get a y60 to be able to mount it. This leads your list looking a bit something like this
PCPartPicker Part List
CPU: Intel Core i9-13900K 3 GHz 24-Core Processor ($569.99 @ Amazon)
CPU Cooler: Deepcool LS720 85.85 CFM Liquid CPU Cooler ($131.99 @ Newegg)
Motherboard: Gigabyte Z790 AORUS ELITE AX ATX LGA1700 Motherboard ($259.99 @ Newegg)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory ($139.99 @ Newegg)
Storage: Crucial P3 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($98.99 @ B&H)
Video Card: MSI VENTUS 3X OC GeForce RTX 4070 Ti 12 GB Video Card ($839.99 @ B&H)
Case: Phanteks ECLIPSE G500A DRGB ATX Mid Tower Case ($159.99 @ Amazon)
Power Supply: Super Flower Leadex V Pro 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($154.99 @ Newegg Sellers)
Total: $2355.92
Generated by PCPartPicker 2023-03-19 12:20 EDT-0400
For free? If so beggars cant be choosers so we gotta work around the cooling issue. @Ryuikko pretty much nails it to the head.
Press quote to get a response from someone! | Check people's edited comments! | Be specific!  🏳️‍⚧️ Rights
Self Introduction and Current Rig
 Share
