Build for professional 3D work
The note regarding an LGA1700 bracket for the NH-D15 is cautionary as older stock may not have the necessary hardware. The bracket is available from Noctua with proof of purchase.
There are issues running 4x32GB on both platforms. If you really must have more than 64GB of memory I'd suggest waiting a few months to let things mature. The other option would be to use an Intel CPU with a DDR4 motherboard.
An AIO is a very good idea for both CPU. Artic Liquid Freezer II 360 has excellent performance. It uses a thicker than usual radiator which eliminates some popular case choices. It will fit in the 5000D.
Why not use an NVMe drive instead of the SATA Samsung 870 Evo?
Edit: a DDR4 option
CPU: Intel Core i9-13900K 3 GHz 24-Core Processor ($569.99 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler
Motherboard: Asus PRIME Z790-P WIFI D4 ATX LGA1700 Motherboard ($239.99 @ Amazon)
Memory: G.Skill Ripjaws V 128 GB (4 x 32 GB) DDR4-3200 CL16 Memory ($289.99 @ Amazon)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($169.99 @ Amazon)
Video Card: Asus TUF GAMING OC GeForce RTX 4080 16 GB Video Card ($1199.00 @ Amazon)
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case ($174.99 @ Amazon)
Power Supply: Thermaltake Toughpower GF3 TT Premium 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($199.99 @ Best Buy)
Total: $3013.93
Generated by PCPartPicker 2023-03-19 00:48 EDT-0400
