Budget (including currency): 500 Euro
Country: Netherlands
Games, programs or workloads that it will be used for: gaming and media consumption
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):
I'm planning on upgrading my current 2070 to a 4080, however, my concern is that my current case (an NZXT H440 blue/black) isn't big enough to fit a 4080 and have sufficient airflow. So I would like some recommendations for a new case that fits a 4080 with enough space for 3 HDDs and 2 SATA SSDs. It should also be able to fit the Noctua NH-15D with one fan up slightly higher due to ram clearance.
The budget will also include a new PSU that I'm going to need as my current Corsair 650W isn't going to cut to feed an R7 5800x (slightly OC'ed) and a 4080. One thing that the case needs is that it isn't higher than my current case (510mm or 200") due to it being on my desk with a cabinet above it.
Thanks in advance for any recommendations you guys can give me for the case and PSU.
https://linustechtips.com/topic/1494523-upgrade-plan-could-use-some-advice/
The NZXT H7 flow is compatible with everything on the list (505mm tall, 400mm gpu clearance, probs 375 with fans and compatible with nhd 15 with raised fan but check the last one)
for the psu I would say that you either go for an rm850x or if you really want to futureproof it for about 40 or 30 bucks more then go with the rm1000x
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
This will all be all in all with the more expensive psu about 350 euros estimate
Total: £1040.95
this one seems to be a good fit except the amount of HDD's spots is less. i was also looking at the Meshify 2 where you can change the layout for more storage space. Thing is however, i dont know if i go that layout, if the GPU will fit with the layout like that (in length it would but not about the width)
If you just want peak value, this would be my config.
Case: Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case  (€88.99 @ Azerty)
Power Supply: Gigabyte UD850GM 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€112.76 @ Amazon Netherlands)
Total: €201.75
Generated by PCPartPicker 2023-03-17 03:12 CET+0100
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
