Help with PC for Gamer
48 minutes ago, itnomink said:Processor : i3 10100F | $69.00
Motherboard : Asrock H510M-HVS | $87.00
CPU Cooler : DeepCool AK400 | $29.99
Graphics Card : Galax Geforce GTX 1650 4GB EX | $210.00
Storage : Kingston A400 512GB |
RAM : KLEVV BOLT X 16GB (8x2) 3200Mhz |
PSU : FSP HEXA 500W 80+ |
Casing And Other Peripherals is up to you
I cant really total the price right now because im in my school device and not bringing my phone. More of it probbably check on ebay, i wouldnt be reccomending a 1070, cause 1060 or 1650 is more popular to me, and also, if you need lower the budgets, make sure you get a good quality power supply
I mostly agree with this
100% build one! It will be great for him and you to this together.
Some things to note
The cpu comes with its own cooler if you get the box so there is no need buy one separately.
I would choose a different mobo to accommodate an M.2 ssd for example Asus PRIME H510M-E which is slightly more expensive.
And if you do check the cpu compatibility in the manufacturers site just to be sure.
You definitely should not cheep out on the psu.. I would get something thats at least bronze certified or gold if you can and avoid anything with less than 3 years warranty but ideally 5+. You can search for the psu tier list to look if the one you chose is on there and its rating.
As for the case you can go really cheap if you want its up to you. Just make sure everything fits and it has the front io that you want for example usb 3.0 ports instead of 2.0. And check if fans are included, if not buy at least 2.
For a more in-depth guide watch https://www.youtube.com/watch?v=BL4DCEp7blY&t=3358s
They explain everything in great detail.
