i play a lot of sim games
in assetto corsa on max settings  on my 1660 zi i get 80´to 90 fps 100 usage temp 60 c
in bus simulator 21 on medium sttings i gte on my 1660 ti 90 fps 100 usage tem 67 to 71c
why is there such difrence in tempeture whan the usage is same
https://linustechtips.com/topic/1493411-2-games-same-gpu-usage-difrrent-temps/
uses different parts of the GPU generating more load, if you check power use you will see more W beeing consumed too.
it might say 100%... but not using all cuda cores.. but total load on other parts equals full load..
you can also use task manager giving a bad graph.. not as exact as something like hwmonitor64.
I don't think that's how it's calculated. Total load on other parts of the GPU would not equal 100%. You have to factor in everything in order to come to a conclusion that the GPU is being used by x percent.
Edited by Godlygamer23
