PCIe 6+2 cable from corsair is incorrect?
Solved by Godlygamer23,
15 minutes ago, KingSpooky said:Yeah the one shown in the picture is labeled PCIe and is one of the 6+2 ends, but the pins don't match the diagram I linked above.
The Corsair cables are correct, the diagram is incorrect. I have a picture of my 970 attached, which has an 8-pin. I also took a picture of my 6+2 cable that plugs into my 970 as well on my test bench. I have them both attached.
