New PC error - GPU red light and fans blink on PSU switch on
Solved by aledsav1,
I think you are probably ok turning it on, that will more than likely just be the psu receiving power and then a trickle getting through to the system, deep breath try it:)
red led on gpu indicates its not gettting enough power, which is correct as the system is not on, but there is power going through the system if that makes sense
Phenz ·
SpookyGhosts ·
Posted in New Builds and Planning1 -
1
mrtwonavels ·
Posted in Cooling0 -
GuiltySpark_ ·
Posted in Tech News20
