8 hours ago, mrtwonavels said:
Hi I’m deciding to upgrade my cooling on my computer.
i want to go with a Corsair AIO with a lcd and some icue link fans because they seem easier to plug in and work with.
any advice
What're your current specs? A corsair AIO is rarely a good option when you've got arctic and an air cooler like the thermalright PA120SE is so much better value that Corsair, especially their iCUE link, makes no sense
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16427946
any advice
Without specs, it's hard to give advice. It would also help to have photos of your computer's insides, and which AIOs you're considering.
Unless you're running a really hot CPU, though, such as the Intel i7/9 12th/13th/14th gen, you don't need an AIO.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16428140
I have the intel core i5 12600k
And cooling that is the cooler master 212 spectrum v3
i really only want and AIO for it being quieter and it looking nicer in the case that I’m buying (lian li 011 mini)
also how would I plug in multiple fans if there’s only one argb header on my motherboard
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16428548
You can daisy-chain the fans together, or use an ARGB splitter, controller or hub.
Which AIOs are you interested in?
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16428578
This one https://www.corsair.com/us/en/p/certified-refurbished/CW-9060060-WW-RF/icue-h150i-rgb-elite-liquid-cpu-cooler-cw-9060060-ww-rf?utm_source=google&utm_medium=cpc&utm_campaign=Refurbished&gad_source=1
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16428579
12 hours ago, mrtwonavels said:
Ok. The H150i is a good AIO, although a bit louder than some people want, and it isn't the best (or the worst) AIO. At normal MSRP, it's overpriced IMHO. Then again, many AIOs are overpriced.
So what questions did you have?
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16428945
Well then do you recomendó d something else
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429041
Yes, please look at the reviews for Intel on KitGuru.com or their YT channel KitGuruTech. The Intel list is far shorter than the AMD list, though, but the link will show you some top-performing ones for your Intel.
It is POSSIBLE that, if you get the LGA1700 BCF, that might make the ones that work well on AMD do better on your 12700k. However, I have no way of verifying that. In other words, I'm speculating - and quite possibly wrong, especially given that although Arctic produced a custom mount for Intel, it performs MUCH worse on Intel than AMD (see link). There are other reviewers out there that have ranking charts, so please do some searching.
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429054
Ok the. Great we’re talking about those contact thingies right
(I’m pretty stupid)
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429064
(I’m pretty stupid)
No worries - there's a lot to learn about tech, and it's constantly changing. This.
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429066
Ooohh ok so if I were gonna get an AIO would I also consider a contact plates.
also any non Corsair recommendations for a AIO
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429492
Well, if your purpose in getting an AIO is for the looks, I would get whatever you think is attractive and you can afford. There are definitely cheaper choices that aren't refurbished, like Thermalright's line (especially the Frozen Notte and the Frozen Magic Scenic V2, which are very performant), and then there are the Lian Li Galahad 2 Trinity Performance, the DeepCool LS720, LT720 and Mystique, SilverStone IceMyst, Endorfy Navis F280 & F360, and a range of others. If you look for comparative reviews on an Intel 12th-14th gen CPU, that should give more ideas.
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429513
Sweet also just for fun would there be any options that have a lcd screen
it doesn’t make sense spending more just for a screen but I might be willing to do it
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429557
If you want to spend a lot more and get performance, it'll cost you. If you don't care about performance and just want LEDs and an LCD screen, it won't be too terribly expensive, but I could be wrong.
I don't really pay attention to LCD screens as I think they're largely unnecessary except for bragging rights and testers, and some LCDs aren't even worth it for testers. Sorry, I can't make specific recommendations. You might want to add that to your original message and then wait a day or two to see if anyone responds. If that doesn't help, start a new thread after that asking about AIOs with LCD.
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429561
Ok after thinking about it for a good 2 secondsI might not get a lcd AIO bit that deep cool AIO looks like a great option
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429565
Your money and your PC, bro.
https://linustechtips.com/topic/1572382-upgrade-help/#findComment-16429566
