Thinking of upgrading my Ryzen 5 3600XT and ASRock B450m Steel Legend. Are they worth changing?
Go to solution Solved by RONOTHAN##,
Upgrading the CPU isn't necessarily a bad idea, a 5600 is a pretty big step up from the 3600 XT, but upgrading the motherboard makes no sense. AM4 is a dead platform at this point, and the motherboard only plays a role in performance if it's inadequate for the CPU, which for the single CCD chips like you're looking at the B450m Steel Legend is plenty. Only reason I see to swap your motherboard is if you're board dies, and even then at that point you're probably better off going for an upgrade to AM5 or 13th gen intel, odds are that it'll end up about the same cost if you're considering going for an X570 board.
8 minutes ago, Mr. Mania said:
I looked into the CPU and UserBenchmark says that between the two I'm looking at (Ryzen 7 5700X and 5800X), there's an improvement of around 15%.
Dont trust User benchmark, their data is about as biased as they come. Use other actually reputable sources instead.
GPU: GeForce RTX 3070 TI
MoBo: ASRock B450M Steel Legend
CPU: Ryzen 5 3600XT
Ram: 16GB
PSU: EVGA 500 GD, 80+ GOLD
I'm currently planning on upgrading my PC. I'm getting a new PSU and 32 gigs of ram. I'm considering getting a new CPU and motherboard as well. I looked into the CPU and UserBenchmark says that between the two I'm looking at (Ryzen 7 5700X and 5800X), there's an improvement of around 15%. I looked into upgrading to an x570 motherboard, and the most I could find is that they're SLI compatible (which I don't care about). I'm not really using my PC to render super complex blender creations or mine bitcoin. I just want to play the latest games, do work and edit videos. At the very most, I'll play some kind of very demanding VR game. Is it worth it in the long run to change it?
I went from a 3600XT to a 5600X.. awesome bump 🤘🏻
AMD R9 5900X @ PBO | Thermalright Frozen Edge 360, 5x TL-B12 V2
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact, TL-B14, TY-143
Thanks.
Any good suggestions?
1 minute ago, Mr. Mania said:
Thanks.
Yes, independent testers like Hardware Unboxed, Gamer Nexus, etc.  Or various review sites that show actual performance graphs and breakdowns.
As above, no need to change motherboard.  It's a foundation is all.  Drop in a 5600, 5600x, 5800x3d etc.   Your best upgrade if the 5800x3d for the money, it's a good pairing with that GPU.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
3 minutes ago, Mr. Mania said:
Thanks.
actual review, for example Hardware Unboxed. They do quite a lot of benchmarking... 3600XT wont be present in the graps but its just a bit better than the 3600X so i would just look at the results for the 3600X and keep in mind that the 3600XT is a tiny bit better...
Would it be good to upgrade to am AM5 board, I don't know much about the specifics.
On what resolution do you play? I have a 5600 (non-X but with a lite OC) paired with my 6800XT and in 1440p ultrawide im still GPU limited most of the time.
if you upgrade to AM5 you would need a new CPU, mainboard and RAM... so not really worth it in my opinion, if you have some money to spend get a 5800X3D and just replace your 3600XT with that...
I have a 4k monitor and I like how it looks, but if there's any performance issues (which there usually are for newer games) I'm fine with dropping it down
actually the higher resolution = less stress on CPU
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
current PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
