Hi everyone,
im new here, if my topic isn’t in right category please accept my apologies.
In recent games, such as spiderman remastered and a plague tale requiem max settings, I have fps drops while my gpu and cpu usage are low, don’t know how to fix it, any help is appropriated.
my rig spec:
cpu: ryzen 7 5800x
gpu: aorus 3080 ti master
mb: msi x570 gaming plus
psu: corsair 1000 gold
ram: 16 gig 3200
res: 1080p
feel free to ask any questions.
https://linustechtips.com/topic/1491903-low-fps-on-my-rig/
2 minutes ago, Akuyu said:
Hi everyone,
my rig spec:
cpu: ryzen 7 5800x
ram: 16 gig 3200
res: 1080p
well what it seems to be on the graph is that your cpu bottlenecked
on whatever game you are playing
i5-9400f
corsair 16gb (2x8) kit + 4x1 gb microsoft stick both 2666
asrock b350m pro4 lga 1151
intel ax-210 wifi card
msi rx 580 8gb
nzxt h510 airflow case white
650w thermaltake gold
512gb nvme
1tb wd blue
1tb seagate external
https://linustechtips.com/topic/1491903-low-fps-on-my-rig/#findComment-15827534
Stop playing at max settings, pretty much look up what settings are actually useful or not. PC ports of a console game can be quite brutal.
Generally you have to adjust settings, 1080p is fairly simple to run, so either some setting is causing MASSIVE Fps drops, not unheard of on console ports, and ive heard of a few issues with plague tail.
Make sure all drivers are up to date, and make sure you have the Ryzen AMD Chipset drivers/
https://linustechtips.com/topic/1491903-low-fps-on-my-rig/#findComment-15827535
Its a plague tale requiem im playing, even though im not at 100%? I heard ryzen 7 5800x is one of mid to high end cpus, and its also overclocked, to 4.5 gigahertz
i have checked it on youtube they had smooth experiences
https://linustechtips.com/topic/1491903-low-fps-on-my-rig/#findComment-15827537
so your at 1080p maxed, with a 3080ti and a 5800x 16gb ram, did you check to see if ram was running rated speeds? try disabling all overclocks and  see what fixes it
i5-9400f
msi rx 580 8gb
512gb nvme
1tb wd blue
https://linustechtips.com/topic/1491903-low-fps-on-my-rig/#findComment-15827541
How should i check ram speed? Will try disabling all overclocked settings
https://linustechtips.com/topic/1491903-low-fps-on-my-rig/#findComment-15827615
in bios, or task manager, ctrl shift esc
i5-9400f
msi rx 580 8gb
512gb nvme
1tb wd blue
https://linustechtips.com/topic/1491903-low-fps-on-my-rig/#findComment-15827817
On 3/4/2023 at 7:05 AM, Akuyu said:
Hi everyone,
my rig spec:
cpu: ryzen 7 5800x
ram: 16 gig 3200
res: 1080p
Again im playing a plague tale requiem
and my gpu usage is 35-40% and cpu 50-55% and my fps is 50!
https://linustechtips.com/topic/1491903-low-fps-on-my-rig/#findComment-15829345
