Hello everybody,
Something is up,  i dont know if it's bad but its at least annoying. I have got a Sabertooth Z87 motherboard and a BE QUIET! darkrock3. After my build at the 5th startup i got an error in dos CPU FAN ERROR thats all it says on a blackscreen with the bios company logo at the top. It then says press F2 to start bios. (Note: the cpu fan spins up) I just quit the bios and windows boots up. I checked in AI suite3 if my fan is working and it spins all the rpm i tell it to. Its my first build and i dont really know what to do. My 4670k is not overclocked wanted to see if it was stable idle temp 23celcius and after 3 hours dishonored on max 43. so i think no issues there. this happend 3 times now in total. Any suggestions?
Thanx
https://linustechtips.com/topic/149128-cpu-fan-error/
you have to plug the fan into the cpu fan header
Eclipse Version 3: i5 9600K | Asus Strix Z390| GTX 1070 | 16GB Kingston Beast | Samsung 840 EVO 500GB SSD [2] +WD Blue 1TB | NZXT H440 | EVGA 750 W | Dark Rock Pro 4| Beyerdynamic DT880 Premium
https://linustechtips.com/topic/149128-cpu-fan-error/#findComment-1992574
Plug it into the cpu fan header. If no fan is plugged into that specific fan header an error will pop up.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/149128-cpu-fan-error/#findComment-1992576
you can turn the "fan error boot stop" option off in the bios. I had to do the same on my r4e
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/149128-cpu-fan-error/#findComment-1992584
I had the same problem on my p8p67m. The fan was plugged on the wrong header and it worked just fine but wasn't recognized as cpu fan. Even after I fixed that for some reason the bios still wouldn't recognize it so I just turned off the sensor. it's always worked perfectly from there.
sudo chmod -R 000 /*
https://linustechtips.com/topic/149128-cpu-fan-error/#findComment-2003745
Could you tell me where exactly in the bios. I cant seem to find it.
NEVERMIND i found it. Did a couple of restarts. does not seem to give the error anymore. THANK YOU VERY MUCH MR SKULLBRINGER. you set me on the right path i just lowered the minimum speed of the cpu fan and now the bios is ok with the 534 rpm of my cpu fan.
https://linustechtips.com/topic/149128-cpu-fan-error/#findComment-2009066
my pleasure!
https://linustechtips.com/topic/149128-cpu-fan-error/#findComment-2009299
  • 2 months later...
