Having issues with adrenaline
Go to solution Solved by 191x7,
1 hour ago, Bombastinator said:
This is sort of a continuation of another thread in PC gaming, but pertains more specifically to the hardware I think.
So I was told I should lock my fps to 60 for a specific game I am running (fallout 4) because I’m having speed issues, so I went to adrenaline which has handy settings for such things, and learned it needed an update.  So I attempted that.  Here my troubles begin:
I downloaded the installer and ran it, but it turns out it’s not actually an installer;  it’s a system checker and downloader which then downloads the installer itself.  The problem seems to be here:  it removed my old adrenaline, then started to download the new one, but it restarts about a third of the way through the download so it is not completed and I have no adrenaline at all now.  The thing says it will restart, so this is somewhat expected, but the problem is it doesn’t pick up the tread and continue installing.  It just presents my PIN code.
so the result is I can’t launch the app to fix anything.
specs: (in case it matters)
CPU:
 12700 (non-k, non-f)
GPU:
xfx 310 SWFT 6800xt
mobo:
MSI mag b660 wifi ddr4
ram:
2x16 t force vulcan(or something like that?)  some cheapass bottom shelf Uber slow CAS 3200mhz ddr4 (needs XMP on to do anything other than default 2166)
Storage:
1 Samsung evo 980 pro 2tb (boot.  I have not so far as I can tell had “the issue” and updating the firmware was fraught with problems)
1 Samsung evo 2tb 970 plus 2tb (steam drive)
1 4tb HDD (backup. Not really setup yet for it though.  It’s just sitting there)
Monitor:
gigabyte m32U
OS:
win11 euro student (unactivated)
peripherals:
 cheapass keyboard, mouse USB3.1 hub, 3.1 external bay for the HDD, the bliKVMHAT is not attached at the moment.
Here you go:
https://www.amd.com/en/support/graphics/amd-radeon-6000-series/amd-radeon-6800-series/amd-radeon-rx-6800
CPU:
GPU:
xfx 310 SWFT 6800xt
mobo:
ram:
Storage:
Monitor:
gigabyte m32U
OS:
peripherals:
Edited by Bombastinator
https://linustechtips.com/topic/1491031-having-issues-with-adrenaline/
DDU and reinstall the AMD driver, downloading it directly from AMD. AMD's in driver updater has never once worked for me, causing basically this exact issue the 3 times I've tried using it. The DDU and reinstall method is pretty reliable though, so it's just what I default to now.
Most of the time the in-app updater works just fine for me, I'd say maybe 1/10 times it gives me trouble, so I've pretty much just resorted to going straight from AMD's site as well.
CPU:
GPU:
xfx 310 SWFT 6800xt
mobo:
ram:
Storage:
Monitor:
gigabyte m32U
OS:
peripherals:
Here you go:
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I will try this.  I went to AMD originally though and what they had was this thing. Did you go anywhere special or different?  I’m hoping to get the full adrenaline and have it work though. The idea is to use one of its features to limit fps.  The game is too old to have a control mechanism it seems.
Fallout 4 is limited to 60fps internally, you shouldn't need to make additional limits. And it's not that old, 2015 was just 8 years ago. Wait what, it feels a lot newer to me...
Sometimes I think of some old games as rather new, probably because I started gaming some 30 years ago.
Downloading now…. I notice there’s a PRO edition as well which is slightly larger.  What is involved with that?  I’d never heard of such before.
Waugh 🤬 it did it again!
