I am streaming in facebook live. I have called my internet provider for additional help with my internet speed and they stated that it looks good to them.
I do not know what to do at this point. I have attach all the screen shots so that you could help me.
Any recommend settings for my streaming is much more appreciated. Thank you in advance.
https://obsproject.com/logs/CCM5tK54uBbvK0IY
https://linustechtips.com/topic/1490454-obs-have-red-kb/
Your internet is not the problem, I have successfully streamed with similar settings at speeds around a third of what you have with no issues.
Make sure all of your drivers are up to date. Try running obs in admin mode and seeing if that fixes whatever undefined issue you have. I see this error in your logs:
Quote
11:14:52.245: D3D11 GPU priority setup failed (not admin?)
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1490454-obs-have-red-kb/#findComment-15817083
You may need to reduce the encoding quality settings. You enabled look-ahead which drastically increases GPU usage and doesn't work well on fast moving content.
F@H
GPD Win 2
https://linustechtips.com/topic/1490454-obs-have-red-kb/#findComment-15817124
Yes, I have tried the to run as administrator. But I have the same issue all over again.
https://linustechtips.com/topic/1490454-obs-have-red-kb/#findComment-15818106
Okay, I will try to untick the look-ahead. I will submit another screen shot for it.
https://linustechtips.com/topic/1490454-obs-have-red-kb/#findComment-15818108
https://obsproject.com/logs/tyT8AaBQZnt34xXb
I have already run it as a administrator but still this is the issue.
https://linustechtips.com/topic/1490454-obs-have-red-kb/#findComment-15818116
Yes, I have already uncheck the look-ahead but still it does not resolve the issue.
https://linustechtips.com/topic/1490454-obs-have-red-kb/#findComment-15818119
  • 1 month later...
