hello so i built a pc around years and half ago or whenever it was the 30 series released 3070 5800x play games around 8-12 hours a day mostly world of Warcraft however i do occasionally play some warzone or red dead redemption god of war and i usually play on the highest graphics i can with stable fps never had any issues before ten today i come to play Hogwarts legacy and i pressed play immediately my pc switched off puzzled i tried again it happened again so i opened msi afterburner turnt up my fan speed to 100% tried again same thing i reinstalled the game same thing i decided to try a occt test on my power supply after 7 seconds it booted off again so i immediately rushed to order a new psu on amazon so i could get it next day but the i become curious what if it weren't a psu issue and a heat issue i tried a occt cpu test after 4 minutes it stopped because my cpu reached 90 degrees could this heat issue also be a psu issue possibly not powering fans i checked my event viewer and i have a kernel power 41 critical error so i think its not just the heat issue and more the psu but i could be wrong if anyone has any knowledge and advice to help it would be much appreciated.
https://linustechtips.com/topic/1490399-help/
Can you list the full system specs, makes and models please?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1490399-help/#findComment-15816699
just ran an occt test with temps capped at 90 this is what i got
00:00:00 - Info - Test schedule started at 2023-02-24 23:49:55
00:00:00 - Info - Power - Started (Duration : 00:30:00)
00:00:01 - Warning - CPU CCD1 (Tdie) sensor overheat ( Current value = 99.75 °C, Maximum Value = 90.00 °C)
00:00:02 - Info - Power - Stopped
https://linustechtips.com/topic/1490399-help/#findComment-15816701
