Docker containers on same subnet as host
I run docker containers inside a VM on my “homelab” subnet. I don’t allow traffic from homelab to management (pfsense, UniFi controller, proxmox etc) subnets, but I want one of the containers to be able to ping devices on management for uptime status using uptime kuma.
I am a relative noob with docker, but it looks like I would be looking for either macvlan or ipvlan for this use case?
I am somewhat confused about the mechanism behind this. I believe macvlan would give the container its own MAC but share IP of the host, where ipvlan would share MAC but provide an individual IP?
Fir firewall filtering, I believe this is all done at layer 3 if I understand correctly. As such, I should use ipvlan so I can punch through only that single IP address. Does this have security implications, such as somehow allowing other containers on that host to break the subnet barrier?
I am not great with networking… so trying to get better.
https://linustechtips.com/topic/1489947-docker-containers-on-same-subnet-as-host/
for macvlan vs ipvlan
- macvlan assigns unique MAC addresses for each device, along with a unique IP address.
- ipvlan assigns a unique IP address to each device, but uses the same MAC address as the parent device for all the devices
ipvlan can have some issues with dhcp and ipv6 addresses, since it would try to apply to all devices.
macvlan can have issues with WIFI, or even affect performance. Some NICs and switches have a limit of MAC addresses per port, so if you are putting a lot of devices through one port, performance can be affected.
I would say that macvlan is best in your case, since I doubt that you are really putting that many devices on one port. Though im not sure about what wireless youre using
as for the firewall filtering, i think what ever VM software youre using should have settings for firewall filtering. not too sure about whether it will punch through.
Thanks for the detailed description.
I run proxmox as my hypervisor, Ubuntu server as the docker host, pfsense as my firewall/router and UniFi networking gear.
I suppose I can give macvlan a shot and see what happens.
I just don’t have a fantastic grasp on networking layers, and where firewalls do their blocking, and what having multiple MAC’s and IP’s on the same port “mean” from a routing perspective.
