Hi I just got and installed a Samsung 980 Pro without heat sink, into my computer and I was wanting to make sure that temperature wouldn’t be a problem. I just swapped the drive with a 970 I got when I first built my computer a few weeks ago but the 980 was 58% off so it got it. I moved the 970 to my bottom slot and put the 980 in the top slot. I put it under a benchmark and it got up to 56-58 Celsius. I did hear that gen 4 can get a lot hotter but I want to make sure it’s being cooled ok. I’ve heard many different things about operating temperature and I wanted to ask about my use case specifically.
Intel Core i7 12700K
Corsair Vengeance DDR5 4800
RTX 3070 Ti
Asus ROG Strix Z690 E Gaming WiFi
Corsair 850w PSU
Samsung 980 Pro 2 Tb
Samsung 970 Evo 1 Tb
https://linustechtips.com/topic/1489786-samsung-980-pro-temps/
  • 3 weeks later...
RTX 3070 Ti
Corsair 850w PSU
I think you should just buy one of those cheap thermal heatsinks off amazon because it seems like your SSD doesn't have enough space to dissipate that heat. Heres a good one if it fits in your case image.thumb.png.1bd1e9723259582cdc30d013a2cadb4a.png
If not then a smaller and cheaper one can be found further down with a second heat sink for your 970 evo too
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1489786-samsung-980-pro-temps/#findComment-15837663
There are multiple reviews that claim or show no evidence of thermal throttling around your temperatures for your SSD model.
If you can feel substancial heat radiating off of it (kinda doubt it with an M.2) and it's super close to a GPU, I guess you could get a heat sink, but then you need to make sure that you have enough room between the heat sink and GPU. Sounds like more pain and $ than it's worth to me unless temps were closer to 75 C, but you do you.
https://linustechtips.com/topic/1489786-samsung-980-pro-temps/#findComment-15837801
