They will both be PWM. One of the connectors is 4 pin and the other is 3 pin. The 3 pin is just missing the "RPM" wire so that you don't have 2 fans reporting their speed through the same header.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1489507-cpu-fan-question/#findComment-15809705
