1 hour ago, PriitM said:
Hello forum
My 7900XTX is arriving tomorrow. Read up the latest 23.2.1 driver is over-writing BIOS settings and causing corrupted windows installs. Confirmed issue?
If so, 23.1.2 is for the foreseeable future...
Much obliged for responses
Idk, I had it installed, everything worked fine, than I went out, my pc went to sleep mode, came back, pc was on, screen was black, replugged cables, didn't get the screen, so restarted pc, and boom, pc booted in to bios, didn't know why, restated second time, same, then I noticed my m. 2 ssd is not showing in bios, like it doesn't exsist, turned pc Off, turned power supply off, waited couple of minutes, turned pc on, booted to windows, ddued 23.1.2, installed 22.11 and that's my story 😅
  • CPU
    Ryzen 5 1600 af 3.2 ghz
    Cooler AMD Wraith Prism rgb
  • Motherboard
    Asrock b450m-hdv r4.0
  • RAM
    16gb g.Skill 2666MHz
  • GPU
    Inoo3d 1650 super twin x2 oc
  • Case
    Genesis titan 750
  • Storage
    Kingston a400 240gb(system)
    Seagate barracuda 2tb 7200rpm(storage)
    Samsung 1tb 7200rpm(backup)
  • PSU
    Fsp si series 700w 50arn 88% efficiency
  • Display(s)
    Dell ultra sharp 24" 1080p
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
    Trust rgb gaming mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1489500-adrenaline-2321-issue/#findComment-15809752
23 series drivers all together un-usable? Did you try any after 22.11?
https://linustechtips.com/topic/1489500-adrenaline-2321-issue/#findComment-15810326
Won't be able to tell, but they haven't even been pushed to recommended, at least in my country , I live in EU, they are only optional, haven't tested other, if there are others, went back to lestest stsble6and that's it 😉
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1489500-adrenaline-2321-issue/#findComment-15810936
im EU aswell. Got Nitro+ 7900XTX.
DDUd old AMD drivers in safe mode, installed only driver from 23.1.2 (should be 22.40.01.34 by AMD homepage). Seems to work on so far. Win 10 1809
i7-7700K is being a real trooper trying to feed the beast 😄
https://linustechtips.com/topic/1489500-adrenaline-2321-issue/#findComment-15811028
