Problems with new DisplayPort cables
Solved by DoctorNick,
26 minutes ago, ricepuff03 said:so i just bought new 4k uhd dp cables and for some reason im running into a lot of problems with my main display with it randomly turning off when tabbing in/out of my game and i dont know why i have a brand new 3060 installed and have two displays the main one is a gigabyte G27FC and a HP 25x display and its the main display which i see little white dots and random screen glitching at the bottom half of my main monitor any ideas?
Did this first occur after you changed the cables? If yes, then the new cables must be the issue
