hey guys so i just finish my first build but when i started to wire the sata cables i notice i was missing one for the optical drive. So could i use the sata cable to use the optical drive to install windows and then turn it off and plug it back in the hard drive. I have both sata cables install on the hard drive and SSD
https://linustechtips.com/topic/148897-first-build-help/
