how would i do this? Can you post your work? It has to be done by writing an equation
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/148891-math-help/
13x + 14y = 350
7x + 9y = 206
solve the system, X is senior price. Substitution is easier IMO.
Solve the second equation for X, so X = 206/7 - 9y/7, substitute that value for X into 13x + 14y = 350, solve for Y, then use Y value to solve for X.
Error: 410
https://linustechtips.com/topic/148891-math-help/#findComment-1989245
13x + 14y = 350
7x + 9y = 206
Goddammit, you beat me to it...
I budget build well. Want to learn? PM me if you want advice.
https://linustechtips.com/topic/148891-math-help/#findComment-1989249
13x + 14y = 350
7x + 9y = 206
Im stuck on the boldded red part, specifically ive divided 7 from all the numbers but what the 9y/7 be?
| F@H STATS |
https://linustechtips.com/topic/148891-math-help/#findComment-1989263
9y/7 is exact value, you can't do anything with that without using decimal approximations, you leave it as is.
When you sub X = 206/7 - 9y/7 into 13x + 14y = 350, you get
2678/7 - 117y/7 + 14y = 350
you can multiply everything by 7 if dividing by 7 is bothering you.
Error: 410
https://linustechtips.com/topic/148891-math-help/#findComment-1989280
What grade are you in? That's basic math to me.
9th our math teacher sucks. He said heres your work for today and didnt explain it and when we ask he takes 20min to explain and then it makes no sense :(
| F@H STATS |
https://linustechtips.com/topic/148891-math-help/#findComment-1989291
sounds like my math 11 teacher. (common trend?)  Only difference is even after the 20 minutes he can't solve it....
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/148891-math-help/#findComment-1989315
