Problems enabling higher RAM speeds
Solved by Radium_Angel,
because XMP is not a guarantee.
Under the best laboratory conditions (etc) it works without issue, but in the real world? Not so much, as you are discovering.
You have two choices..manually tinker with voltages/speeds/timing and see what you get
or
leave XMP off and don't worry about it
PopsicleHustler ·
Posted in Audio2 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory10 -
11
play_circle_filled
Latest From ShortCircuit:
