Hey Guys,
I will order this pc and wanted to ask if the 13900k will be keept cool with the AIO i have chosen or if its a good cooler
Or is there a Better Cooler for the same or less price would be cool if someone could look around the website and help me
Build in mind
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/8ba27b221c309c71fad1d88b4113098ff59df1881e6bc717622
https://linustechtips.com/topic/1488368-13900k/
5 minutes ago, xBl4ckR4in said:
Hey Guys,
Build in mind
I would go with a Arctic Liquid Freezer 360 or 420 instead. Better priced and much better performance! (also much more quiet)
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1488368-13900k/#findComment-15801715
9 minutes ago, xBl4ckR4in said:
The 360 isnt on the website they dont have them and i think it the 420 doesnt fit in the case 😕
Yeah thats right. 420 dosen't fit, But 360 will. Can you buy from somewhere else? Else the 280 will still be better than kraken z73. Also do you already have case? If not, get another case that can support 420😄
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1488368-13900k/#findComment-15801748
2 minutes ago, xBl4ckR4in said:
Sadly cant buy from somewhere else is there any other AIO on the website you would recommend for a 360
Forgot to Tag you my bad
Not really, apart from the 280
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1488368-13900k/#findComment-15801758
Besides the price, I’m curious what’s wrong with the z73.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1488368-13900k/#findComment-15801773
Because it's controlled via nzxt cam software over Internal usb. Cooling wise it's not impressive, just the usual asetek aio. Because the design is intellectual property of asetek, price is too high compared to eg. Arctic freezer which is designed in house. Arctic only uses motherboard pwm to control both fan and pump speeds and no software is required.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1488368-13900k/#findComment-15801975
