Hello everyone recently i bought 2 more stick of ram and install my motherboard all 4 of my rams are the same but i cant run all 4 of them at 3200mhz stable pc keep turning off and turning on until hit the bios with default 2400mhz speed but its stable at 3000mhz is it worth up the voltage to 1.35 from 1.4 if its gonna make the ram stable or should i leave it on 3000mhz i dont think 200mhz gonna make huge difference but im open on any information.I also try separately in case one of them was the problem its not even with 3 sticks cant run 3200mhz (Btw before i try new 2 stick pc was running 3200mhz fine with 2 sticks. btw all of my rams are the same and same latency down below i show you the ram) my cpu is ryzen 5 5600 and my motherboard is asus prime b450m-a II
CPU: Ryzen 7 5800X3D | Motherboard: Gigabyte B550M-DS3H | RAM: HyperX Fury 3200Mhz 4x8GB | PSU: Sharkoon WPN GoldZero 750W 80+Gold | GPU: MSI RTX 3080 Ti VENTUS 3X OC | Case: DeepCool Matrexx 55 Mesh | Storage: KIOXIA EXCERIA 1TB SSD PCIe M2G2 NVMe 3D and Kingston NV2 1 TB | Cooling: CPU: DarkFlash Twister DX240 240mm AIO
https://linustechtips.com/topic/1488346-unstable-memory-speed/
This is likely the reason:  asus prime b450m-a II
Ill pull up the owners manual shortly here
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801585
The board doesnt state in the manual that i could find that using both channels can have a reduced frequency (example, my ASRock B450 with 4 sticks runs at a lower speed than in the A1/B1 config per the manual).
Are you on the latest BIOS revision?  Each update adds more compatibility across brands etc (especially if you are mixing RAM modules of different bins etc)
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801590
it would be great its says it can support up to 4400 mhz but doesnt actually say how many ram can use that speed.
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801592
tbh i dont really know how i can check my mobos bios but i can say i didnt do any bios update for 5600 its came like that in factory i use the 4 same brand and model but i didnt buy them all in one i bought it separately but i make sure that all of them are the same model and same speed and latency.
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801594
Are you using the DOCP/XMP profile or are you setting timings manually? The profile is only optimized for running a single stick at 3200mhz. Normally you would buy a kit with 2 or 4 sticks. Try settings frequency manually to 3200mhz and setting primary timings to 16-18-18-36 like so, in BIOS:
If it doesn't work, try increasing voltage to the memory controller a little bit. (if you set to auto, it should up itself a bit, so I would try that first).
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801596
tbh when i try to select docp even doe its says 3200mhz doesnt set my ram to 3200mhz even before i run 4sticks. it was always sets 2400mhz i dont why but also i have 2 docp profiles one is 3200 one 3000mhz i usually choose 3200mhz docp and also manual set to 3200mhz
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801598
Turn off PC, press and hold F2, turn on PC, will go into ASUS bios.
But Im an idiot, that CPU is not gauranteed to run at 4400mhz.  3200mhz only
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801599
I dont if this help but on CPU-Z its like this
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801603
Alright, try setting this manually instead. Yes the kit comes with two profiles, and the profile will set sub timings aswell. Apart from being optimized for intel and not amd, it should work, but only guaranteed to work with one stick. Does it make sense? If you set the primary timings to 16-18-18-36 as well as manually setting voltage to 1.35v and 3200mhz, all other timings will be set by the motherboard.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801604
i didnt touch any of the timing because i dont know anything about them but will give to try if i have to do it manually.
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801609
Yes set it manually and it might just work without you doing anything else.
primary timings to 16-18-18-36 as well as manually setting dram voltage to 1.35v and 3200mhz
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801611
just try it when switch to profile 3200mhz docp its automatically sets all of them 16-18-18-36 also voltage sets 1.35 automatically too
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801628
My Bios version and also the ram settings in bios @DoctorNick @Tristerin
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801630
Yes, thats the point. But it doesn't work right? Thats why you'll have to do it manually.......
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801632
will give it to try
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801635
Put it were you had it, then highlight Dram voltage push the + once or twice 🧙‍♂️
                          Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - 7700Xt
                                                           X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
 ~Extra L3 cache is exciting, every time you load up a new game or program you never know what your going to get, will it perform like a 5700x or are we beating the 14900k today? 😅~
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801651
-snip-
What I was getting at, and had forgotten, is that the CPU itself, has its own memory controller.
So does the motherboard
Motherboard can go up to 4400mhz per the manual
CPU can go up to 3200mhz per the manual
Lowest common denominator is spec, anything else is overclocking.  Id manually set it to 3200mhz if DOCP is having an issue (and make sure BIOS is up to date)
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801662
well i did disable doc and set everything myself manually and didnt work i guess cpu can run 3200mhz with only 2 sticks and not 4sticks. im fine with 3000mhz tbh i just wanted to know if i was doing something wrong. also my bios up to date
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801677
Swap the kits around to and try agian, should support 3200mhz, but could be the board as a B450 and they just dont have that listed in the specs (as well)
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801726
will give it to try in the future thank you all for inputs and suggestions
https://linustechtips.com/topic/1488346-unstable-memory-speed/#findComment-15801880
