Power supply making "blink" sound and not booting!
Solved by mariushm,
You may have some short circuit somewhere.
Remove cables, get down the minimum possible, like the 24 pin and 8 pin for cpu. Take out video card. Make sure the cpu fan is properly inserted in the fan header, and it's not accidentally plugged improperly. Try starting without video card. If it works, add the video card...
Don't plug rgb crap until the very last.
Put the cpu cable to the header closer to the socket, sometimes it matters.
