I'm looking for a wireless controller for my PC, and I find all the ones I've tried too small. So far, I've tried the Xbox Series X controller, PS4 DualShock controller, and the 8bitdo Ultimate. I don't really care about features, all I want is it to be wireless, be supported by Windows, and have vibration, and be $80 or less. Has anyone found a good controller for large hands?
https://linustechtips.com/topic/1488173-best-controller-for-big-hands/
1 hour ago, Coolmaster said:
I can't find anywhere that sells them anymore, I don't want to buy used.
Oh well thats unfortunate as they only exist used anymore.
The switch pro controller might be something for you too? It's a bit chunkier not as chunky as the wii u one tho
Hyperkin makes a modern version of the original Xbox "Duke" controller which was a meme in its day for its prodigious size, but it's wired only.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
