BackPlate replacement HELP
Go to solution Solved by ApolloX75,
I have one of those backplates. It works fine. There's nothing dangerous about it, it's adjustable to fit pretty much all the LGA variations new and old. It won't break anything.
Hi i was browsing for a aio and I came across a Corsair H115i Pro rgb for $50 so i bought it and it didnt come with the backplate and I didnt realize til now and i cant return it so i went browsing on the internet for backplate replacements because I already bought the retro fit things for lga 1700 and I bought this back plate on amazon for my aio and mobo will this work or will it mess up my computer PLS someone SEND HELP i dont wanna mess up my very first PC.image.thumb.png.12ecdebd8938726528374a263b37361e.png
https://linustechtips.com/topic/1488096-backplate-replacement-help/
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
