So I wanted to update my cpu and chipset drivers because I saw someone saying it will boost your fps, so I tried.
I went to the AMD site and selected my cpu(ryzen 5 3600) and downloaded the latest drivers, the same for my motherboard(msi b450 tomahawk max).
But every time I opened them, it showed me this message: image.png.a80238b5e87220935b14ccc097229992.png
So I went online and tried to fix this problem, I saw someone saying they downloaded windows troubleshooter and deleted every amd file and after that it worked fine, so I gave it a try.
I downloaded it and deleted everything with amd in its name, then I tried running the driver setup and the same window popped up again.
Now I am left with no drivers and I don't know what to do...
Please help!
https://linustechtips.com/topic/1487522-driver-problems/
Is that an official thing by Microsoft?
Try booting into safe mode and installing the drivers that way
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
https://linustechtips.com/topic/1487522-driver-problems/#findComment-15795342
Please help!
Download the chipset driver from msis website https://www.msi.com/support/download
https://linustechtips.com/topic/1487522-driver-problems/#findComment-15795357
