DRAM Light
Solved by RONOTHAN##,
1 hour ago, loubig1983 said:HWM showing over 2v on a core
HWM has issues reading AMD system information, so odds are that's gonna be wrong. Use HWINFO64 or Ryzen Master to read them.
1 hour ago, loubig1983 said:I am thinking that my M-board is bad but wanted to ask
I'd be more suspicious of a BIOS issue than anything. Are you on the latest revision or have you tested a couple different versions? AMD does have the habit of every once in a whole putting out an update that breaks something related to memory support (on AM4 for instance there are 2-3 BIOS revisions where I can't get 3600 CL14 to POST, whereas other revisions will work at 4000+ CL14), so it's worth checking a couple to see if one of them makes it better.
