Currently, I have a Corsair H60 2018 ed aio cooling a 2700x in a Thermaltake Verse N21 ATX. I plan to upgrade my case to a corsair 4000x and my cpu to a 5700x and would like some help wondering what I should pick for a cooling unit aio or air cooled and would like to stay under 100
Edited by FunionsFTW
for context
https://linustechtips.com/topic/1487414-need-help-picking-a-cooler/
Depending on the workload on the CPU, you could just get some thermal paste and reuse the h60, that should be fine cooling the 5700x for gaming workloads. I doubt you'd have any throttling issue provided the h60 is still running fine. Otherwise, I'd recommend the Deepcool Ak620 for air cooling, I'm not as up to date on the recent aio's so I don't want to speak prematurely on what to buy, but at least a 240mm if you are planning to get rid of the H60.
Fractal Design Define S | Asus X570 TUF Gaming | AMD Ryzen 7 5800X3D | Corsair Vengeance Pro RGB 32gb 3600mhz ram | Asus TUF Gaming RTX 5080 |
Corsair RMx 1000w PSU | Corsair H115 Elite Cappellix | Micron M600 M.2 256Gb SSDs | WD SN850X 4TB NVME | 2TB Samsung 860evo | 1440p 240hz LG UltraGear 27GR95QE OLED | 1440p 155hz Dell S2719DGF | LG 29WP60G-B 1080p 75hz Ultrawide | GMMK TKL | Glorious Model O2 mini
Your current cooler should be fine. Just clean it and apply new thermal paste.
