I need some help
Go to solution Solved by PlenumRated,
I would just search for monitors with <10ms response time and the monitor resolution i would go for is 1920x1080(Full HD). For that resolution you'll need to connect the screen with a DVI or HMDI cable. DisplayPort is also an option but i don't know for sure.
Hoped this helped!
Also i see you're Dutch (Yeah me to! :D ) and a website i would recommend for buying computer stuff is Alternate.nl, i've bought my monitor there also.
Monitors under 5 ms are better.
Hoped this helped!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/148656-i-need-some-help/#findComment-1985651
I am looking for a monitor to game with for about 100 to 200 euros
and a question whats the best way to connect your pc to your display?
I'd recommend the ASUS VS24AH-P, VS239H-V.
CPU-AMD FX 8350 @ 4.9Ghz | GPU-Sapphire 7970 OC | Motherboard-AsRock Extreme9 990fx | RAM-8GB Mushkin Blackline Ridgeback
Case-NZXT Switch 810 | Heatsink-NZXT HAVIK | SSD-Samsung 840 250GB | HDD-Seagate Barricuda 1TB; WD Green 2TB
PSU-Seasonic X-Series 850 Watt | Mouse-Razer Naga | Keyboard-Razer Blackwidow | Speakers-Logitech z623
https://linustechtips.com/topic/148656-i-need-some-help/#findComment-1985757
Hoped this helped!
"Just another day at the office" Captain Price -Call of Duty
https://linustechtips.com/topic/148656-i-need-some-help/#findComment-1985761
Dutch Website: Azerty.nl Also they could be Cheap on Markplaats.nl or maybe a Yard Sale or a Recycled Products Store I picked up my 1920x1080 Display for 40€ (but my dad Broke it..., I got 2x 1280x1024 in return from him)
I wouldn't buy a second hand monitor, but if you want to go for a second handy i would buy it at tweakers.net and not Marktplaats
https://linustechtips.com/topic/148656-i-need-some-help/#findComment-1985813
Hoped this helped!
Yeah but there aren't a lot of monitors under 200 with <5 ms
https://linustechtips.com/topic/148656-i-need-some-help/#findComment-1985816
Markplaats has More Offers and Tweakers is ussually More Expensive, and Also I wouldn't Buy a Second Hand Monitor aswell they don't have Warranty and you can't buy the Type and Brand you want you can only buy the Ones that they Offer.
at the end i bought a 27ea73 from lg for 179 euros at a staples
https://linustechtips.com/topic/148656-i-need-some-help/#findComment-1991429
