So i recently made a new build and it has trouble loading stuff A LOT, while browsing its quite fast but when alt tabbing its slow and the colors change (might be because i am alt tabbing into a screen that is connected to a USB dock (that also has hdmi)) so the colors change, hdmi screen does not have hdr, main monitor that IS plugged into gpu does support and have HDR enabled
specs: 6750 XT, ryzen 7 5700x, 1 stick of 16gb RAM, 750 Watt PSU, B550-F Gaming motherboard
the only thing i can think of that makes the pc slow, is the NVMe drive, 1GB of Write, 3GB of Read, 256GB
Yes everything has the latest drivers (checked Armoury Crate and websites of manufacturers + looked up Hardware ID's)
Any thoughts? Feel free to ask for more info
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1486433-slower-than-expected/
Ryzen is severely bottlenecked by not running dual channel RAM.
But that is not the issues here.
Have you disabled hardware acceleration in the browser?
tried disabling MultiPlane Overlay MP?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787198
Just now, aDoomGuy said:
Your 1 RAM stick is holding you back. Also why use a USB dock for display out? Surely that's gonna make it even worse.
1 ram stick only makes about 2% performance difference right? no reason for it to bug out a lot, and the dock is bc i dont want fps drops from my gpu handling 2 monitors
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787199
most of the time the browser is not open (while having said issues), but i could try that
ive never heard of MultiPlane Overlay MP, where do i find this?
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787203
Unless you actually game on two monitors you will not see a difference. So feel free to plug it into your GPU with no noticable penalty.
You're running in single channel and that cuts your bandwith in half.
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787206
alright, does bandwith matter when it comes to just opening apps already installed?
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787219
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787226
4 minutes ago, 191x7 said:
i do indeed have a grey screen right after boot and sometimes when starting games, and some flickering on thumbnails when hovering over them on youtube, thank you
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787230
my coworker says that single channel shouldnt matter and its a first hes heard from single channel being an issue
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787260
Just now, heatonpkmassive said:
Your coworker is wrong then.
i have a spare 4gb ram module, could i place this in with the 16gb and it would be no issue? image.png.ad80a1acc57d8de715a2fae5c6d595d1.png
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787321
Your coworker might not be well informed or might be inexperienced, maybe taking into account old data or a different platform.
Pretty much.
I would advise against doing asynchronous dual channel (16+4; so you'd have 4+4 in dual channel and additional 12GB which wouldn't be dual channeled).
But the screenshot you provided shows you having 8GB memory and using 2 slots on the motherboard.
Can you open up RamMon from Passmark and post a screenshot here?
https://www.passmark.com/products/rammon/
This is an example of my work PC:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787356
Pretty much.
so how much difference would another exact stick of ram make? bc im dying here, i have that MultiPlane issue you sent me, plus apps are so damn slow, likesometimes discord takes 1 sec to startup, and other times it can take 2 minutes, same with my voice software and any other programs, sometimes programs even refusing to start up (plus how much does it affect fps?)
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787469
my coworker is my supervisor and has been doing tech for 12+ years so it would be weird
and i will do this when i am home
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787478
So you still didn't solve the MPO issue? It's a simple registry edit!
And where's the RamMon screenshot?
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787479
i cannot do this right now since i am at work, i have sent the link of this topic to my pc at home via email so i will do everything listed here whenever i am home, please wait patiently till then, i will continue trying to find things in case some of the things listed above do not work, as alternatives, do you mind if i keep asking things in case they are not clear? (sidenote, i only have 1 stick of ram in posesion, i will need to buy an extra 16gb stick next month)
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787496
The screenshot you provided clearly states you have 2 out of 4 slots used. Can't do that with a single stick. That's why I'm asking for a RamMon screenshot.
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787500
this is my work pc, would you like a sample of this pc too then? the pc i have been talking about is my gaming pc, this is my work pc, different configuration, different location
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787502
Oh, you never mentioned that small screenshot wasn't from the PC we all are talking about.
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787505
yes sory, i was taking that screenshot to ask you if the ram from this pc is compatible, since i have some spare laying around at work
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15787506
heres the screeenshot
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15788062
You can get the same RAM or you can sell the one you have and buy 2x 8GB.
What about MPO?
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15788085
What about MPO?
i did the 2 registry files
Setup:
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15788093
Which 2?
If you used the regedit files
ONE disables MPO, the other enables it. Lol
https://linustechtips.com/topic/1486433-slower-than-expected/#findComment-15788100
