My server has a loud Flex ATX PSU fan. Is it dangerous to swap it out?
Solved by LIGISTX,
2 minutes ago, OverjoyedDonut said:The fan's plug is inside the PSU. That's the part that has me concerned.
You can likely swap it for a better fan, but if you don't know what you are doing... PSU's, no joke, can kill you.
I would say if you are unsure, just buy a different PSU, or transplant what matters into a new ATX case and use an ATX PSU.
