I’m at a loss, I have gigabit internet that works great on everything except my Desktop
RYZEN 7 5800X3D
ROG CROSSHAIR VIII HERO WI-FI MB
Windows 11
When I run speed test it starts out fast 200Mbps for a Second then drops down to 20 the 15Mbps and finshes Finishes 15-18Mbps
thats on Wi-Fi and with Ethernet (I uninstalled and reinstalled drivers with no luck)
So I thought maybe it’s the internal Wi-Fi and Ethernet on MB so I installed a new Wi-Fi 6e adapter i disconnected internal Wi-Fi and installed new PCIe adapter and still same results. Not sure where to go from here I’m stumped
https://linustechtips.com/topic/1486345-slow-connection-speeds/
it should be an option on your router called QOS or adaptive QOS,
it usually prioritizes connections over the other for latency and connection efficiency,
I had a similar problem with this issue you're describing that ended up being the ethernet WAN cable being broken in several areas from my room to the host modem.
ethernet cables usually default to lower speeds when broken in case of fire hazards to the cable being exposed. try swapping it.
PERIPHERY
- Table : IKEA Karbly 8FT counter top (brown) w/ 2 ALEX black drawers & OLOV LEG
- Chair : Herman Miller Aeron Remastered Ergonomic Chair
- Mouse 1 : Logitech Superlight X 2 (Black) (Using Now)
- Mouse 2 : Razer Viper V2 Pro (Black)
- Keyboard 1 : Logitech G413 SE Brown switches Lubed
- Keyboard 2 : Ducky One 2 SF Black CherryMX Silver Switches
- Monitor 1 : Benq Zowie XL2566K 360HZ 0.5MS
- Monitor 2 : ASUS PG279QE 1440p 165HZ
- Mousepad 1 : The Glorious 3XL Extended Mousepad (Black)
- Mousepad 2 : Benq G-Sr Speed Mousepad (Black)
- Mouse-Bungee : Razer Bungee V2 (only when wired)
- Headset : Beyerdynamic DT990 PRO 250 OHM grey/black
- Microphone : Shure MV7 XLR
- Mixer : TC-Helicon GOXLR
- Camera : Nikon 250D W/ Elgato CAMLINK 4K
- WebCam 1 : Logitech Brio 4K
- Webcam 2 : Logitech C922 1080p
- Controller : PS5 Controller Whiteout Edition
PC
- CPU : Intel I7 12700KF
- CPU-Cooler : NZXT Kraken X62
- GPU : Zotac Gaming GeForce RTX 3070 Ti Trinity OC 8G
- Motherboard : MSI MAG Z690 WIFI
- RAM : Corsair Vengeance Pro RGB 64GB
- Case : NZXT H700I Black/Red matte
- HDD : 2x 6TB (12TB) Seagate Exos 7E10 12GB/s
- SSD : 1TB Crucial P1 NVME M.2
- PSU : Corsair RM1000X (1000W Plus Gold) (W/ Red Sleeved Premium Corsair Cable kit)
https://linustechtips.com/topic/1486345-slow-connection-speeds/#findComment-15786614
https://linustechtips.com/topic/1486345-slow-connection-speeds/#findComment-15786683
RYZEN 7 5800X3D
Windows 11
https://linustechtips.com/topic/1486345-slow-connection-speeds/#findComment-15786970
