Help with PC flashback
Solved by -rascal-,
12 minutes ago, Uby said:Hello! I have just built my pc and I’m using a b660 aorus ddr4 master and I’m using a 13th gen i5 and I just put the usb in and it’s reseting alot and the red led is not moving or turning off so is this normal? Also it has been on for about 10 minutes
Did you follow the Q-Flash Plus instructions included in the the 'Unique Features' Document?
Did you follow the instructions word-for-word on how to prepare the BIOS file, and how to use the feature?
Basically:
- Download the BIOS file you want to update from Gigabyte.
- Unzip the download.
- Rename the BIOS file to GIGABYTE.bin
- Prepare a USB stick. Format is to FAT32.
- Put the renamed BIOS file (GIGABYTE.bin) into the USB stick -- DO NOT put it into a folder, etc. Directly copy-paste into the blank USB stick.
- Plus the USB stick into the Q-Flash Plus USB port.
- Press the Q-Flash Plus button.
You also need to use the SPECIFIC USB port in the back of the motherboard that works WITH Q-Flash Plus.
