Hi so i’v never got a rack mount case before so I apologies if what i’m asking for doesn’t exist.
I need a PC case that supports any size up to 4U but a depth of 400mm as my rack mount housing is only 450mm deep and I think 50mm should be enough for cables.
Ideally about to support a normal PSU not a server one and a full size PSU if possible, support for 2 HDDs, full ATX motherboard as i’ll be running a 10th gen system. I don’t need any space for a GPU as I won’t have one.
Iv been looking for something that fits this build but a lot of the server cases don’t tell you information of what they support like regular PCs.
Or even if there is a way to rack mount a regular PC case that fits the size specs i’ll do that too. Any suggestions would be great thanks
https://linustechtips.com/topic/1485431-rack-mount-case-recommendations/
the issue you're gonna find, is that the front chunk of most rackmount cases is for drives, not cables, and they're a lot more than 40mm deep.
This might be as close as you find:
https://www.silverstonetek.com/en/product/info/computer-chassis/RM51/
there are some very short depth chassis out there, but ususlly the drive mount options for those are pretty much terrible.
i found this one, which is 380mm deep: https://www.yakkaroo.de/19-inch-4U-server-chassis-IPC-G438-38cm-short
but it's from a german site and shipping might be expensive.
They aso have some other options like this 300mm 3U option: https://www.yakkaroo.de/19-inch-3U-server-chassis-IPC-C330-30cm-short
Thanks, i’ll save this
That’s a good options but sadly it’s just a little too tall at 5u
1 hour ago, thrasher_565 said:
That’s a pretty good idea, I might look for another case as that one is a little expensive but I really like the idea of just making a DIY one
You can get rack mount shelves and then set a regular case on top of that as well. I did this for a while before I got dedicated rack mount casesPXL_20211218_010702263.thumb.jpg.b6f19c38572a884f840220ce5e55f3a9.jpg
EDIT: and with the rosewill 4U:
If your question is answered, mark it so.  | It's probably just coil whine, and it is probably just fine |   LTT Movie Club!
Read the docs. If they don't exist, write them. | Professional Thread Derailer
Desktop: i7-8700K, RTX 2080, 16G 3200Mhz, EndeavourOS(host), win10 (VFIO), Fedora(VFIO)
Server: ryzen 9 5900x, GTX 970, 64G 3200Mhz, Unraid.
rack mount case are not cheap. home theater case are not cheap but like Takumidesh said can use a cheaper case and a shelf.  the 4u draw is not that cheap ether and most likely cost as much as a home theater case in the end but its a blank canvas if you have the tools and now how that is.
Edited by thrasher_565
