Laptop won’t output sound via HDMI
Kanna
Hello, I’m using a Laptop of the model lenovo ideapad gaming 3, and I’m hooking it up to my TV using a regular HDMI cable, tried multiple. But audio just simply won’t show up in audio devices and I don’t see why it doesn’t as all drivers are up to date, but that’s as far as I get whem it comes to simpler googling and troubleshooting. Help much thankful
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
HDMI is connected to Nvidia or Intel GPU?
Did you accidentally disabled it? Try tick both of these.
check in device manager for hidden devices and see what the error code is.
Main PC:
CPU: AMD Ryzen 5 5600X | RAM:Corsair LPX 3200 mhz (16Gb)
Mobo:ASUS Strix B550-F Wifi | GPU: MSI RTX 2070 Gaming Z
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Be Quiet straight Power 10 500 watt
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Samsung 8 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
The HDMI is connected to the only HDMi port on the laptop, which would probably be the intel GPU since I’m at low load. Also that menu I mentioned in the post it doesn’t show up, at all. But I might have been a bit vague
I have been in device manager to look for hidden devices, But I’m unsure how I would see what the error code is, idk what device it would be either tbh. Realtek high definition?
Reminder⚠️
That would be Intel high definition audio or nvidia high definition audio depending on which GPU your HDMI port is wired up to.
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
I don’t seem to find any of those, only these which show no error
Reminder⚠️
Try open from control panel or press Win+R and run this control mmsys.cpl sounds
What window btw?
What window btw?
Still same results as already stated, Windows 10, latest updates that I can get with my device that is organization controlled
Reminder⚠️
Intel high definition audio is greyed out which means it's installed but the system is not detecting the driver. Does it show it's working Ok under ''events''.
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
It says it was started like many hours ago today, and then configured, nothing about status, there is on the general tab tho saying that the hardware device is not connected to the computer
Reminder⚠️
Connect your monitor to the HDMI port and see if it changes to connected. Then you need to potentially manually change your output device in the soundmenu.
If that doens't work reinstall your Intel GPU drivers from intel's website.
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
I'm not sure now, I can see Intel SST there so that mean it available. Try disable Realtek in device manager and hopefully it will change to Intel SST.
Or completely remove Intel SST driver so it will revert back to the default HD Audio Device.
I want to share the fact I should have started with, it’s been hooked up all the time already 😅
Unfortunately removing intel SST for digital mocrophones didn’t help this case, maybe I should contact the administrator of the organization and they can check?
Reminder⚠️
Yea.. don't do his/her job for free. 😛
