got nothing to do with the quality of the motherboard.
if it;'s support SAM, it will do just fine.
It's a basic feature build in the CPU and motherboard chipset, so motherboard quality or tier won't matter.
As long as the CPU and the board supports SAM, then you will be able to enable SAM.
Occassionaly visits the forum when I have nothing to do at work.
And the GPU.
For example, rtx 3000 need vbios updates / firmware updates.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
8 hours ago, Rumman said:
But I am getting stutters with my Rx 6600xt, B450M S2H Mobo and Ryzen 3600x. Can't find any solution of this problem.
Do you have the latest bios for your motherboard?
Are you using the latest chipset drivers downloaded from AMD?
The latest GPU drivers?
Have you tried disabling Multiplane Overlay MPO and Ultra Low Power State ULPS?
