322mm gpu for 330mm Case
Go to solution Solved by matt0725,
322 is less than 330, so i don't see the issue, besides that it will be very close. If by stock coolers you mean the fan then you should be fine. you can't mount anything else in the front obviously
You'll be fine.
28 minutes ago, zsekel said:
Thanks! But I have one more question. On the website it says that the gpu needs a 750W psu. Will a 650W psu be enough?
I'm on an RX 6800 right now, no issues with a good 650W PSU.
