It looks like those fans are a bit loud, but are you running it at 100%?
5 minutes ago, AmirAcle said:
how do i check if im runing them at 100%?
What fan header is it plugged into?
8 minutes ago, AmirAcle said:
do you have any reccomendations for quit fan for hyper evo ? the defualt fan was also bad
I'm using CoolerMaster MasterFan MF120R aRGB (https://www.coolermaster.com/catalog/coolers/case-fan/masterfan-mf120r-argb/). It has a good air static pressure, having 2000rpm max speed, and quite silent in my case, even when running the fan at full speed. Maybe you can give it a consideration?
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
4 hours ago, AmirAcle said:
i found it to loud
Yeah the 120 is actually louder than the 140 I think lol 😄
But loud as feck that is for sure.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
